Hmooslechner
picture in GDL without borderlines in 3D??
The picture command unfortunately only knows one setting for an always visible border line
Who knows a simple way to work around this?
so - to get an GDL image -simply resizeable like the picture-command -  without border lines in 3D.
1 Solution
Pertti Paasky
This works in 3d.
mask=0
rotx 45
group "pict"
if picturename #"" then PICTURE picturename, a, b, mask
endgroup
placegroup "pict"
addz 2
repl_directive = 0
j1=0!: replace pen,
j2=0!: replace material,
j4=1!: make edges invisible.
repl_directive = j1 + 2*j2 + 4*j3 + 8*j4
pen_= 1
material_=0
placegroup CREATEGROUPWITHMATERIAL ("pict", repl_directive, pen_, material_)
- AC-24 FIN - WIN 10 - HP Zbook -
“A winner is just a loser who tried one more time.”
George M. Moore, Jr.
Go to post
5 Replies 5
DGSketcher
Legend
Shot in the dark, have you tried different pen settings before the picture command including background and transparent. The frame makes reference to using RECT which doesn't have pen settings so I assume relies on the PEN setting.
Hmooslechner
no - unfortunately not - i cant turn it off completely to just show the picture without the lineframe with the pen-setting.
runxel
You can't have that with PICTURE, Heimo.
Either use a Graphic Override to get rid of the outline.
Or just use "DEFINE TEXTURE" with any geometry.
This might be the best option.
Pertti Paasky
This works in 3d.
mask=0
rotx 45
group "pict"
endgroup
placegroup "pict"
addz 2
repl_directive = 0
j1=0!: replace pen,
pen_= 1
material_=0
Hmooslechner
Thank You - it worked fine!
@Pertti Paasky wrote:
This works in 3d.
mask=0
rotx 45
group "pict"
endgroup
placegroup "pict"
addz 2
repl_directive = 0
j1=0!: replace pen,
pen_= 1
material_=0
I did it for the whole group i already had with all pictures in it:
repl_directive = 0 !!! GDL Handbuch Seite 183
j1=0!: replace pen,
j3=0!: ????
pen_= 1
material_=0
if OhneRahmenLinien = 1 then
  placegroup CREATEGROUPWITHMATERIAL (Wandvorsatz, repl_directive, pen_, material_)
else
   placegroup Wandvorsatz
endif
For What:
https://forum.Graphisoft.de/viewtopic.php?f=6&t=28872
