archigreen
"walhole" not working
For some reason the "WALHOLE" comand is not working to make custom wall openings. Where can one chose, eg. slab, to be editable or not?
ArchiCAD 26
MacOS Monterey
MacBook Pro Apple M1 Max
64 GB
2 Solutions
Lingwisyer
Guru
If you are assigning a slab in the floor plan as "WALHOLE" then save it out as a window or door, your spelling is the issue.
Go to post
Yes, the ID of the Slab must be "WALLHOLE" with 2 "L" characters, not with 1 "L".
Go to post
5 Replies 5
Can you share the part of your code where you are using "WALLHOLE" so the issue can be evaluated?
Creator of Cadswift's parametric GDL libraries
Creator of Infinite Openings and Component Catalogues
Push the envelope & watch it bend
website: https://cadswift.com.au/
YouTube: https://www.youtube.com/user/CADSwift/playlists
Lingwisyer
Guru
archigreen
Thanks, Laszlo
My bad. It used to be with one L long time ago. I guess I am getting old.
ArchiCAD 26
MacOS Monterey
64 GB
Lingwisyer
Guru
+1 IDE update w/ autofill.
