GDL
script windows missing
Mark Chen
Hi there,
does anyone met this issue before?we like to create a new GDL object but script windows are missing.
Archicad 27 CHI, support package in attachement.
Regards,
Mark
9 REPLIES 9
Lingwisyer
Guru
This was brought up when AC27 was first released. There is a thread around here somewhere...
Probably in the beta or tech preview forums which are closed now.
I can't recall the solution though.
Mark Chen
Hi Barry,
by chance we can recall that solution ?
Mark
Lingwisyer
Guru
Probably easier to ask one of your collegues at GS to dig it up, given the fact that I assume those forums have now been completely removed, not just hidden.
Hi Mark,
I seem to recall there being posts about it, but maybe I am just imagining that.
I can't remember if it was in the Beta testing or the Tech Preview.
It seems I can still access the Beta bug reports, but I couldn't see anything there.
I can't access the Tech Preview forum.
And I can't remember if there was a solution or not.
I think I even experienced it myself in the first Beta version.
I don't remember doing anything to fix it other than version updates.
Sorry I can't help more.
Peter Baksa
Sometimes just closing all running Archicad's helps.
As next step, try deleting %USERPROFILE%\AppData\Local\Graphisoft\Monaco-... before starting Archicad.
If these don't solve it, the problem might be that your Windows username contains non-ASCII characters. It will be fixed in the next update.
Péter Baksa
Software Engineer, Library
Graphisoft SE, Budapest
I think Peter has the solution.
I can remember that being discussed before now.
Hi Peter,
thank you! we will try it.
Mark
Hi Mark,
I'm facing the same difficulty as you did.
Have you managed to fix it?
Can you tell me the solution😢
thanks a lot to you!
Shiki
