GDL
values{2} List - Custom Parameter Question
GDL Enthusiast
I have a values{2} list. The list entries are standard lengths of timber. I would like the last entry as Custom, to enable the user to enter a value for variable Timb_L i.e.,
values{2} "Timb_L",  0, ` Length A:`,
                                  1, `Length B:`,
                                  2, ` Custom:`
My hope was to use “” as the result for the user selecting #2 i.e.,
IF Timb_L = 0    THEN Timb_L = 1000
IF Timb_L = 1    THEN Timb_L = 1050
IF Timb_L = 2    THEN Timb_L = “”
PARAMETER    Timb_L = Timb_L
However when I add this “” part of the code into a larger script, the UI keeps blanking out as soon as item 2 is selected. Is there a way to provide an IF THEN which allows the user to manually enter a value using values{2}?
I also tried:
IF Timb_L = 2    THEN Timb_L = Timb_L
And I tried not even having a value for 2:
Many thanks, Matt
DGSketcher
Legend
You need two parameters TL1 & TL2.
TL1 contains your option values.
Your object uses the value in TL2
If TL1  = 0 then TL2 = 1000 and lock or hide TL2
If TL1  = 1 then TL2 = 1050 and lock or hide TL2
If TL1 =2 then do nothing but unlock TL2 for manual entry
You may want to set a range of values for TL2 to control custom entry or preset lengths.
DGSketcher
Legend
Oh that is brilliant, thank you so much DGSketcher!
