Hi Bill,
Thanks for the explanation. I actually agree with you on both counts.
Unfortunately, there is not much we can do about the renaming things. Actually, some of those things is not really renaming. For example, the IFC Scheme Setup Dialog used to be the place where you could define what IFC Properties are be available in your Project File, it allowed you to define custom IFC Properties and it also offered you the ability to map values to IFC Properties.
The Property Manager kind of replaces that. GS wants us to be able to define ARCHICAD element properties and use that instead of defining and using custom IFC Properties. So the IFC Scheme Setup Dialog and the Properties Dialog are not the same, but they are used to achieve similar aims. This is why the IFC Scheme Setup Dialog is no longer available in ARCHICAD.
I agree that definition and clarification of terms is important, not only because we need to know what things mean, but sometimes the same thing is called something else in another application, or the same name is used for something else in another application.
So these are all useful suggestions.
As far as I am concerned I will make sure the people doing training materials will know about this as I will forward this thread to them.
