2 weeks ago
- last edited
2 weeks ago
by
How can I solve this issue; I have a door opening but the wall end of the opening do not show the wall lineweight, the same linewidth on the wall lateral lines.
Is it in the MVO, the door opening settings or the wall settings?
Solved! Go to Solution.
a week ago
This happens when "Ganging" is enabled for both sides of the Door Opening.
When you check the "Ganging" option for either side, the division line of the Door/Window (or in this case, the Wall End Line of the Door Opening) is not drawn because it indicates you want to place another of the same library part next to it.
a week ago
- last edited
a week ago
by
Given the blade wall at the top left is also missing it's closing line, check you wall settings.
Ling.
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
a week ago
The Wall End Lines setting does not have an effect on those lines of the Door Opening. Only the Ganging options have.
In the below example, I set Wall End Lines to "None" and the lines are still drawn if Ganging is turned off. So Ganging is what affects it.
2 weeks ago - last edited 2 weeks ago
Please include a screenshot highlighting the issue you are pointing out.
https://community.graphisoft.com/t5/Our-Community/Creating-a-Thread/td-p/361315
2 weeks ago
a week ago
a week ago
- last edited
a week ago
by
Ling.
a week ago
a week ago
- last edited
a week ago
by
@Laszlo Nagy schrieb:
... an effect on those lines of the Door Opening. Only the Ganging options have.
And this one has:
German AC27 standard door, might be different elsewhere (in time and space).
