Tuesday
- last edited
Tuesday
How can I solve this issue; I have a door opening but the wall end of the opening do not show the wall lineweight, the same linewidth on the wall lateral lines.
Is it in the MVO, the door opening settings or the wall settings?
Solved! Go to Solution.
Wednesday
This happens when "Ganging" is enabled for both sides of the Door Opening.
When you check the "Ganging" option for either side, the division line of the Door/Window (or in this case, the Wall End Line of the Door Opening) is not drawn because it indicates you want to place another of the same library part next to it.
Thursday
- last edited
Thursday
Given the blade wall at the top left is also missing it's closing line, check you wall settings.
Ling.
Thursday
The Wall End Lines setting does not have an effect on those lines of the Door Opening. Only the Ganging options have.
In the below example, I set Wall End Lines to "None" and the lines are still drawn if Ganging is turned off. So Ganging is what affects it.
Tuesday - last edited Tuesday
Please include a screenshot highlighting the issue you are pointing out.
https://community.graphisoft.com/t5/Our-Community/Creating-a-Thread/td-p/361315
Wednesday
Wednesday
Thursday
- last edited
Thursday
Ling.
Thursday
Thursday
- last edited
Friday
@Laszlo Nagy schrieb:
... an effect on those lines of the Door Opening. Only the Ganging options have.
And this one has:
German AC27 standard door, might be different elsewhere (in time and space).
