2024 Technology Preview Program
General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Hotlink label is not linking to window elevation
Loutro
Hello, when placing a hotlink label on a window in elevation, the link is not working, the label just says "<Hotlink ID><ID>".  For some reason it appears that the label is not sensing the window object--after clicking on the label tool, usually I hover the cursor over the object and it highlights in green to show the connection is being made, but that is not happening anymore.  Is there a setting somewhere that I am missing?
Thanks in advance,
- L
Archicad 24
Cadimage
Loutro
I couldn't find the associative button in the settings (command + T), but today I do see it at the top of the screen.  However, it is only selectable after I click on the label tool to create new.  If I select a label that I've already placed, that associative option at top of screen is greyed out and can't be selected.  In any case it is working now as long as I place a new label.  Thanks,
Loutro
Is the label geometry method set to "associative'?
Loutro
Loutro
To associate an existing label to an element, select the label then CTRL click the element you want to associate to.
I assume that is the command key on Mac?
