2024-05-15 05:25 PM
Hello, when placing a hotlink label on a window in elevation, the link is not working, the label just says "<Hotlink ID><ID>". For some reason it appears that the label is not sensing the window object--after clicking on the label tool, usually I hover the cursor over the object and it highlights in green to show the connection is being made, but that is not happening anymore. Is there a setting somewhere that I am missing?
Thanks in advance,
- L
Archicad 24
Cadimage
Solved! Go to Solution.
2024-05-16 04:05 PM
I couldn't find the associative button in the settings (command + T), but today I do see it at the top of the screen. However, it is only selectable after I click on the label tool to create new. If I select a label that I've already placed, that associative option at top of screen is greyed out and can't be selected. In any case it is working now as long as I place a new label. Thanks,
Loutro
2024-05-16 03:50 AM
Is the label geometry method set to "associative'?
2024-05-16 04:05 PM
Loutro
2024-05-17 04:16 AM
To associate an existing label to an element, select the label then CTRL click the element you want to associate to.
I assume that is the command key on Mac?
