We value your input!
General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
Hotlink label is not linking to window elevation
Loutro
Hello, when placing a hotlink label on a window in elevation, the link is not working, the label just says "<Hotlink ID><ID>".  For some reason it appears that the label is not sensing the window object--after clicking on the label tool, usually I hover the cursor over the object and it highlights in green to show the connection is being made, but that is not happening anymore.  Is there a setting somewhere that I am missing?
Thanks in advance,
- L
Archicad 24
Cadimage
Mac OS 14.6.1
Archicad 24 & 26
Loutro
I couldn't find the associative button in the settings (command + T), but today I do see it at the top of the screen.  However, it is only selectable after I click on the label tool to create new.  If I select a label that I've already placed, that associative option at top of screen is greyed out and can't be selected.  In any case it is working now as long as I place a new label.  Thanks,
Loutro
Mac OS 14.6.1
Archicad 24 & 26
Is the label geometry method set to "associative'?
Loutro
Loutro
Mac OS 14.6.1
Archicad 24 & 26
To associate an existing label to an element, select the label then CTRL click the element you want to associate to.
I assume that is the command key on Mac?
