2026-08-31
07:48 PM
2026-09-01
08:27 AM
Noemi Balogh
Do I understand that with ver 28 NOTHING we have created in 27 or prior can be inported or copied into a 29 project.
2026-08-31 09:07 PM
You should be able to use everything. Barry gave you the solution in the other thread:
2026-09-01 07:48 AM - edited 2026-09-01 07:50 AM
If you need help with libraries then look up the manual;
> Migrating to Archicad 29 > Migrating Libraries to Archicad 29
https://help.graphisoft.com/AC/29/INT/#t=_AC29_Help%2F010_MigrationGuide%2F010_MigrationGuide-4.htm
there is an option at the bottom to download the migration library
(this will place those missing library object if they were standard Archicad objects, but this will increase loading time)
if you add this migration library to your new projects, it might help with the missing objects.
I don't know if this will help, but you can try.
