OmarA
Suddenly Archicad creates file scr_xxxxxxx
Suddenly Archicad creates file scr_xxxxxxx that i can't open, so i lost a lot of work...so strange.
there are someone that happened the same???
src_xxxxx extenzion has a big KB dimensione... looks like a BackUp  File but it's impossibile menage!!!!
help please
omar
2 Solutions
Lee Hankins
I’ve been using iCloud on the Mac for years. I have the option where the Documents and Desktop folder remain fully synchronised all the time across all devices. I had an issue with AC24 I think where every time I save a number was appended to the file but I never had an issue with data loss or a scratch file being left behind. This seems to be fixed now with the newer versions of Archicad. However, Barry is correct in that Graphisoft’s advice is not to use cloud based storage.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Go to post
I think it may just be luck sometimes and how fast Archicad can save the files and if cloud sync kicks in before it is done or someone else is messing with the file at the other end of the cloud.
Archicad has to create the scratch file (which we don't usually see), then rename the PLN as BPN and then save the scratch file as PLN.
Usually it is fairly quick.
But if it gets interrupted, I think that is when things go astray.
Also I think if you save in Archicad (this may trigger the cloud to sync straight away) and then quickly save again in Archicad, things might get messed up.
Just speculation of course.
If you need a cloud system for the files, use BIMCloud.
Go to post
7 Replies 7
Lee Hankins
That looks like a scratch file where Archicad has tried to save and there has been an issue. Are you saving to a local disk or a cloud based storage?
Lee Hankins
macOS Tahoe (26.0)
OmarA
i just saw in another forum..the problem is icloud sync...
but now can i open o recover the stracht file???o is a corrupt file and imposssible use?
thanks lee
Lee Hankins
You may be able to rename it and add .pln to the end to see if Archicad will open it. There will also be the autosave folder that may contain the last good save of the project if you haven’t relaunched Archicad. Even if you have it may still be worth checking. Do you know how to find the location of the autosave folder?
Lee Hankins
macOS Tahoe (26.0)
OmarA
`Wonderful!!! resolved!! just renaming the file and .pln! like you have written...
thanks so much
omar
Don't work directly in a cloud sync folder.
Work on the file on your hard drive or network and copy it to the cloud sync folder only when you want it to be synced.
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
