General discussions
Posts about job ads, news about competitions, events, learning resources, research, etc.
archicad replacement icons (mac)
schagemann
dear all,
i am sure we are not the only one who struggle following which AC version you are currently working in, particularly since the default AC logo has remained unchanged for quite some time...
... and so we decided to create our own and make it available for everyone - actually since we are trained architects like most of you, we made a few options...
1. column: transparent white outline
2. column: white
3. column: transparent
please download the respective versions from the following posts.
enjoy,
ds.
macinteract
Design Technology Managers.
All  on macOS | since AC 6
Archicad Framework > Smart Template 27
Smart Tree, Transmittal and Universal Label and other smart GDL Objects
By Architects for Architects.
Eszter Fulop
For those who have difficulty distinguishing the original launch icons, we’ve introduced new alternative icons that prominently display the version number for easier identification. You can find all the details about the icon changes in this Knowledge Base article:
https://community.graphisoft.com/t5/Getting-started/Introducing-alternative-launch-icons-for-Archica...
Please read it carefully, as the previous solution some of you used is incorrect and may cause Archicad to mistakenly be flagged as a pirated version. To avoid issues, kindly follow the guide in the article.
Thank you!
34 REPLIES 34
schagemann
And for AC21 a slight deviation from so far almost religious following of the Graphisoft branding - looks like we are growing up after all...
https://macinteract.com/ac21-replacement-icons/
macinteract
schagemann
And so we forgot to post our ARCHICAD 22 replacement logos...
https://macinteract.com/ac22-replacement-icons/
macinteract
schagemann
And now for some ARCHICAD 23 replacement icons for completeness sake...
https://macinteract.com/archicad-23-replacement-icons/
macinteract
schagemann
What a change for 2020... Graphisoft has rebranded!
So without any further ado here are our alternative / replacement icons for ARCHICAD 24.
To ease the transition to the new identity for die hard / nostalgic ARCHICAD users, we have also included a LEGACY version...
https://macinteract.com/archicad-24-replacement-icons/
macinteract
schagemann
It took us more than a year to realise that we did not post the replacement logo for Archicad 25, so here a double post for both AC25 & AC26... enjoy!
https://macinteract.com/Archicad-25-replacement-icons/
https://macinteract.com/Archicad-26-replacement-icons/
macinteract
If only Graphisoft would do this. 🙄
25 & 26 are so similar it is ridiculous.
At least 24 & 25 had a different shape.
Barry
Just for completeness sake, it seems GS might finally consider a proper solution and save us the trouble each year...
https://community.graphisoft.com/t5/General-discussions/Archicad-Launch-icon-Can-you-spot-the-differ...
macinteract
schagemann
Hurrah another version...
https://macinteract.com/archicad-27-replacement-icons/
macinteract
Please be very wary doing this. We replaced the icon on one of our macs and it triggered Archicad in to thinking it had been pirated which caused us a bit of an issue with Graphisoft having to explain ourselves.
Lee Hankins
ArchiCAD 4.5 - Archicad 28 Apple Silicon 27.3 | 28 Apple Silicon
macOS Sequoia (15.1.1)
Very sorry about this - we had inadvertently uploaded only the PNG files instead of the actual ICNS
files, thus the replacement would not have worked.
Please note we have now uploaded the correct ICNS files (same link) please try again.
PS > We could not help to also redesign them... 😃
macinteract
Eszter Fulop
Thank you!
Thanks for finally providing an offical solution.
For all long-term followers of this thread (since 2009), please note we will no longer produce Archicad version icons as this solves the problem.
However, if you prefer to produce your own graphic / icon, please refer to the following instructions:
https://smart.macinteract.com/icon-creation-tutorial-for-macos-apps/
macinteract
Thank you @Eszter Fulop
Now, if those alternative icons can be saved in the 'Archicad Starter.exe' file (and Mac equivalent) for each new version, then that would be perfect.
We won't have to find and download the new icon as it will already be delivered with Archicad installation.
Thank you.
Just FYI, when updating Archicad you have to replace the icon again and recreate any shortcuts/aliases you have of it.
Lee Hankins
