Patrick M
file damaged... over the weekend?
how does a file send/receive just fine on a friday, then when joining in on Monday, when no one has worked on it for 2 days, report as damaged?
hoping this team has a back up/snapshot that will recover without much lost work...
tag this in the ongoing saga that is BIMcloud lost work and bugs 
3 Replies 3
DimitriusMega
hey @Patrick M ,
sorry to see this happening. you can always reach out to us whenever this happens for troubleshooting, preferably by creating a ticket or through email. It's also good to keep track of the issues you're having, specially after the latest update for AC29. I've seen this happen before - but there had been change during the weekend and outside elements had been added that corrupted the file. remember there's always the possibility to Rollback the snapshots from BIMcloud https://help.graphisoft.com/BC/INT/index.htm#t=Topics%2FBCManager_Projects_Topics%2Ft_RestoreSnapsho... . It may also be worth checking if another team member is able to open it.
Best regards,
Patrick M
other team members were able to access and work in the file. we ended up just deleting this one designers local data and re-joining; but it's just more in the ongoing saga of teamwork hang-ups, malfunctions, and bugs
Which version of AC You use ?
GRAPHISOFT BIM Manager Training Week attendee
ArchiCAD v9 - v29 INT / NOR
cpu i5-12600K @ 5.0Ghz, ram 32GB, gpu 1060 GTX
ssd NVMe, Windows 11
ArchiCAD Discord channel: https://discord.gg/QdWxSJ33
