2008-05-19
12:58 PM
2024-05-03
12:02 PM
Aruzhan Ilaikova
2008-05-30 01:08 PM
greenfin wrote:laszlonagy wrote:Thanks. Good to know that as we'll be using Macs... So is there really a 'visual compare' icon somewhere or is this 'splitter' thing it?
Now, I do not think this is different between Mac and Windows.
The instructions were not correct.
And the saga continues (I can only do one chapter a day as I'm still working with Revit)...
Create the Slabs called for by the “3.2.3 Slab-04/03” pre-set
View. After creating the outline using SPACE-click,
SHIFT-click the newly created Slab while the Slab Tool is
active, and click the polygons that are pointed to by the other
Labels to create the holes within the Slab polygon. These
holes will be cut into the body of the Slab.[/color]
I followed the instructions as described above but the holes do not appear. I clicked on 3D to see if maybe they're there somewhere where I can't see them on the plan, but there was nothing on the 3D Window, not even the slabs I'd been working on. I zoomed in, zoomed out, panned. Nada! What did I do wrong?
2008-05-30 03:35 PM
laszlonagy wrote:
You created a Slab. If you select it, its surface should be marked by a greenish color (that is called the Selection highlight). Then you you need to define another closed polygon within the contours of the Slab polygon to create a hole in it.
2008-05-30 04:53 PM
Thomas wrote:6. Don't forget to delete the polygon afterwards. It will still be there after magic-wanding. Use shift-tab to cycle between the newly created hole and the existing polygon in order to select the correct one for deletion.
This way:
1. Create slab.
2. Draw a polygon (with a line tool, circle, polyline, whatever) within its perimeter. (Note: If you draw with the slab tool still active, you will create the hole at once. The method described here is more useful for pre-created polygons)
3. Select the slab.
4. Click on Slab Tool.
5. "Magic wand" the polygon. (this is done by pressing the space bar and clicking on the polygon. I guess the text you read should be Space-click). THis method is extremely useful in many situations.
2008-05-30 06:42 PM
greenfin wrote:I suspect you did not have the Slab Tool active.Create the Slabs called for by the “3.2.3 Slab-04/03” pre-set
2008-05-30 11:30 PM
2008-05-31 01:50 AM
greenfin wrote:It's the same in AC, you just have to hold down the Shift key
you simply click on the element or use tab to toggle among overlapping elements.
2008-05-31 02:59 AM
greenfin wrote:Actually I find that the selection tools and the polygon editing are two areas where ArchiCAD beats Revit all hollow.
...selection is more straightforward in revit. you simply click on the element or use tab to toggle among overlapping elements. to cut a hole on a slab however may not be more complicated than in archicad but may take more steps... or not.
2008-06-02 11:23 AM
Matthew wrote:yeah, i find the magic wand a great tool indeed. but i still am not sure whether to use shift-click, space-click or a regular click in a given situation. i guess with practice it will come.greenfin wrote:Actually I find that the selection tools and the polygon editing are two areas where ArchiCAD beats Revit all hollow.
As has been pointed out ArchiCAD's basic selection method is no more difficult than Revit's and the more advanced tools go way beyond anything Revit has to offer.
Polygon (slab, roof, fill, etc.) editing is available instantly on any selected element in plan and 3D with many features just a click away on the pet palette. Revit requires going into sketch mode, fussing with relatively primitive editing functions, and then you don't know if it will actually produce valid geometry until you leave the sketch mode (and have to undo and re-enter the sketch mode to try again if it fails).
I really like using Revit for some things and there are plenty of cool things in the program, but these two areas have actually been my two biggest frustrations with using it. Particularly the lack of selection tools. I can work around the clumsy polygon editing by associating floors, ceilings, etc. to walls - at least when there are walls to work with.
2008-06-02 06:32 PM
laszlonagy wrote:THE SLAB TOOL SHOULD BE ACTIVE.
The hole creation should work.
2008-06-03 02:44 AM
2008-06-04 11:36 AM
2008-06-04 12:17 PM
2008-06-05 09:37 AM
Brett wrote:there's no 'Z' on the pet palette, "top row far right" on my palette is 'stretch height'. i would pick elevate but no box appears where i could enter height. i haven't gone so far as to customize the tool boxes, just following instructions in the exercise. here's a screen shot of the palette.
10, "Z" means in the pet palette that appears, top row far right,(not the Z on the key board), which will bring up the height box to enter height.
2008-06-05 10:24 AM
2008-06-05 10:49 AM
Brett wrote:I had the roof (slab) selected but there's no 'Z' in the palette for the fascia (wall) either. So what is this 'Z'? I tend to think it's the keybord Z for entering the height or Z coordinate the way you could with X and Y. Only when I press it nothing happens, no box to enter height appears. I guess the content of the pet palette changes depending on the view you're in but in 3D it should be active, no?
Yes I didn't read it properly,I was talking roof only, but without knowing what the fascias are made out of, there's a different pet palette for walls, slabs,roofs etc. Try turning on the tracker. It makes editing things like this a lot easier.
2008-06-05 11:01 AM
2008-06-05 04:27 PM
2008-06-05 06:12 PM
2008-06-05 06:48 PM
greenfin wrote:Shift click = select/deselect regardless of the active tool (also accumulate/de-accumulate selections)
as to the pet palette, i'm sure it's very handy but at the moment it somehow irritates me as it gets in the way and sometimes for some reason not all the tools are there.The tools on the pet palette vary according to the element being edited. It will take some time to get used to, but is well worth the effort. Generally the lower row of tools are general purpose (move, mirror, rotate, etc.) that apply to anything, while the upper row are the functions that apply specifically to that element.
and i don't like that you have to delete the remains of the polygon after you've created the opening (referring to making holes for a skylight in ArchiCAD BIM Experience Kit).As others have said, it is usually just as easy to draw the hole directly as it is to draw the polyline. The magic wand approach is mostly to punch holes to match existing geometry or when the form is so complex that you want to fuss and tweak it with 2D tools before making the hole. Of course now in the skylight case, if you can use one of the skylights in the library, the hole is automatic (shades of Revit, oooh).
hey matthew, did you switch from revit, too, or is it your job as a 'consultant' to be on the know? what are you a consultant of, if i may ask?I guess you could say I am a BIM consultant, though I don't care much for the acronym. I still prefer Graphisoft's "Virtual Building" and I kind of like the new "IPD" or "Integrated Project Delivery" as it applies to the construction process.
2008-06-05 06:59 PM
Matthew wrote:Also, it is important to note that the Pet Palette for each tool will vary whether it is an element's edge or node that is selected.
2008-06-05 07:04 PM
