Graphisoft Technology Preview Program 2024
AC28 Materials
NigelMX
It appears that there is a great number of materials missing from this beta version of AC28 compared to what is/was in AC27.
will more be added for the final release?
1 REPLY 1
Jan Millan
Archicad 28 Tech Preview uses the “Archicad 28 Generic Template.tpl,” which is similar to the “INT” template and not the final template traditionally included with each language version’s full release. This may explain the difference in materials compared to AC27. It’s also important to note that different language versions of Archicad have region-specific templates, which can vary significantly from the International (INT) template. If you’re accustomed to using a language version other than the “INT,” this could explain why you’re noticing missing content.
Jan Millán
Senior Customer Success Manager, Graphisoft
Graphisoft Certified BIM Manager
