Graphisoft Technology Preview Program 2024
Blue back ground screen in 3D window
iggiv
Team:
I do not find any conversation on this issue so it must be something I am doing wrong.
Where do I turn off the "Blue Background" on the 3D window, Also in Favors Pallett?
Yes that is the Physical Based Rendering sky.
You have to turn PBR off in Work Environment > More Option > Experimental Features as runxel mentioned.
4 REPLIES 4
russfairhurst
The 3d styles palette. Can change backgrounds, shading type, shadow and line type. Bottom right corner of screen.
Windows 11 Intel Core i9-13900K RAM 128GB NVIDIA GeForce RTX 4090
runxel
Legend
However this could also be due to the "experimental" PBR view being set to "on" in the work environment.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text | My List of AC shortcomings & bugs | I Will Piledrive You If You Mention AI Again |
Yes!! That was the problem. I turn off the:
Work Environment > More Options > EXPERIMENTAL FEATURES
Enable Property Update in Hotlink Modules
Thank you very much
