Wednesday - last edited Friday by Laszlo Nagy
Unable to change door window renovation filter setting once placed. It is placed as a new object and can't change it to existing or anything else. It grays out. Mark G
Solved! Go to Solution.
Wednesday
Your wall is set to "new", too 😉
Quite obvious, when you think about it! In a to-be-build wall can not be an existing window.
Wednesday
Friday
my bad:) You are correct. Thanks for noticing.
