2024-07-05 05:33 PM
New, improved Distance Guides is no more experimental and available for everyone by default. It comes with the following new features:
For more information please visit the following link:
Improved Distance Guides - Graphisoft Community
Looking forward to having your much appreciated feedbacks, questions and insights.
2024-07-26 03:51 AM
I have another item for the Wishlist about the Distant Guides (I am sure others have thought of the same thing before, apologies I haven't read all about it).
I think the basic principle of the Distant Guides being sensitive to Walls, Columns and Grids does work in most situations.
But perhaps one could "force" the Distant Guides to appear against edges highlighted using the Snap Reference like on the screenshot attached.
Thanks.
2024-07-26 05:51 AM
I agree with this. I have had trouble using the distance guides with the design options. The guide seems to default to the main model objects rather than those linked to the current design option setting.
2024-07-26 10:53 AM
i agree Tony, the Guide lines should be controlled by snap reference (lines an points).
2024-07-26 10:55 AM
I think this is a brilliant idea! This should be the first priority above grids.
2024-07-26 03:57 PM - edited 2024-07-26 04:04 PM
Hi @tkrepler_fjc,
Did you try to use Snap points/guides with Distance guide? I think distance guides can't read aligned or curved distance otherwise perpendicular one which can be adjusted by Snap guides as in this short video.
2024-07-29 02:29 AM
I know Mahmoud, hence the suggestion for the wishlist.
Wouldn't it be cool if it worked?
Thanks,
