License Delivery maintenance is expected to occur on Saturday, October 19, between 4 and 6 PM CEST. This may cause a short 60-minute outage in which license-related tasks: license key upload, download, update, SSA validation, access to the license pool may not function properly. We apologize for any inconvenience.
Graphisoft Technology Preview Program 2024
Improved Distance Guides
Illes Papp
New, improved Distance Guides is no more experimental and available for everyone by default. It comes with the following new features:
  1. Context sensitive Stretch & Move - Distance Guides recognize the longitudinal and perpendicular directions of beams and walls and offer stretch and move respectively based on the context.
  2. Relink Distance Guides freely - You can relink Distance Guides to virtually any supported points or edges that you can snap to during work.
  3. Door / Window Nominal Size and Axis Support - Distance guides support nominal size settings of doors and windows and will link by default based on these settings. You can also switch Distance Guides to link to Axis instead of the nominal sizes, better supporting workflows and design stages when that is the most important input.
For more information please visit the following link:
Improved Distance Guides - Graphisoft Community
Looking forward to having your much appreciated feedbacks, questions and insights.
Illés Papp
GRAPHISOFT Senior Product Manager
25 REPLIES 25
@Jeliszej Korcsak wrote:
I couldn't reset the guide endpoints to the other side of the wall or any other junction.
I find the guides are almost useless for placing new elements and you can't adjust where the guides measure to.
But place the element and then drag it, and you can set the measurement point.
I guess you need to give DGs more practice to digest it well,
in my first case guides were measured from the reference line as attached below.
*In this case I could change the reference line location to the other face so i could measure easily from that edge, you don't have to change the element's position to change its reference line location, you can use (Modify wall reference line) via toolbar or the Edit menu, I hope that helps.
* The attached photo is taken from V27 as the tooltips function is not working well in V28 & I sent a ticket regarding this.
AC 27 INT 5060/WIN 11
Instead of playing around with what side of the wall the reference line is on (this can have other implications in your model), or what part of the wall the distance guides measure to (edge or reference line), I find it just easier to place the window (or element anywhere).
Then select and drag and then it is easier to reset where the distance guides measure to.
That way you can measure exactly to the point you want.
Of course, I can see how your solution is the best way to use DGs but I scare it can be the only way to use DGs.
Could you please share the ticket number, you have mentioned?
Illés Papp
Hi @Illes Papp
 Do you mean the ticket number regarding Tooltips disorder?
This is the one I've mentioned.
Here it's the ticket number link,
https://support.graphisoft.com/hc/requests/162425
BTW I had a reply from GS via @Gino Hansen.
This is the method I use without guides as well. So in this case you just don't win anything with the guides, because you place your object anywhere and then drag it in relative distance from any object you want. if you use the new guides the same way then you didn't save any clicks.
Of course I understand how hard it is to create a tool that can read minds... 🙂
Jeliszej Korcsák
Architect, BIM Manager | ArchiCAD 27 HUN Build 4030 on Windows 10 Pro 22H2
Eduardo Rolon
Have disabled them again.
They keep showing up always in the wrong place for me to select an object and never work ok as a reference.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
tkrepler_fjc
I find the distance guides really interesting, and quite helpful with orthogonal, straight walls. Yet, in our design as my colleagues used to say "There is nothing straight". Hopefully, in a future release of Archicad, they will work in skewed, curved environments as well. If it is not there yet, my wish is: please put it on the Wishlist. 😃
Thanks.
Tony Krepler
Design Technology Lead - BIM, fjcstudio
Sydney, Australia
Archicad since 3.4, macOS 13
