Friday
With CiTools Keynote you could assign Keynotes to various different attributes such as Composites, Building Materials etc.
I cannot seem to find this feature in the Keynote tool, am I missing something or it is planned in future release
Thanks
Domenic Iacovitti
Gartner Trovato Architects
Monday
Hi @DomenicI
The solution inside Archicad 28 was built from the ground up and integrated into existing Archicad functions. The CI solution is a separate add-on, and has been around and updated for far longer.
Can you describe the workflow further what you'd like to see with the built in Archicad Keynotes solution?
Thanks.
James.
