Graphisoft Technology Preview Program 2024
SOLVED!
Keynote not expanding for additional text
NateLumen
We don't typically use keynotes, but if we did....I could imagine a case where we would want to add additional text to it, to clarify or specify something. I would hope that the Keynote frame would expand to include this text, but it doesn't seem to (see attached).
I am a little confused how to tell the difference between a keynote and a regular note. Once I click it I can see the keynote "autotext" in red, but otherwise they read very much like notes. Should it be its own tool?
1 ACCEPTED SOLUTION
Solution
Olivier-IDAO
Hi NateLumen,
See attached files.
Interior designer, Former & Bim expert
Archicad 6.5 to 27 now
MacStudio 2023 Apple M2 Max powered by MacOS Sonoma 14.5
3 REPLIES 3
Solution
Olivier-IDAO
Hi NateLumen,
See attached files.
NateLumen
Right right right. Just saw that too. Thank you.
Does a Graphic Override help?
https://community.graphisoft.com/t5/Beta-Program-2024/Keynotes/m-p/614239/highlight/true#M859
