2024-01-06 07:22 PM
Hi, I'm encountering the "Bad image error" after having installed Archicad 27 on my laptop, running on Windows 11. I have an educational license.
When I try to run Archicad, first, I get the Bad Image error, with a message suggesting that one of the wibu-tls files in not designed to run on Windows or contains an error (error status is 0xc0e90002).
Then when I press OK, I get the second message- "TLS initialization failed", saying that my organization used Device Guard to block this app.
Well, I've spent good 5 hours trying to disable the Device Guard. That didn't help. Re-installing Archicad is not a solution either.
Any ideas?
2024-03-02 05:11 PM
Hi I have excactly the same Problem. Did you find any solution?
