3D Shadows are Wrong
Has anyone else had this issue?
I find that I build a model and everything is fine but as the complexity grows it seems there is a 'breaking point' and then I can't get rid of these triangular shadows everywhere...
3 Replies 3
I have not seen this happen with shadows.
I would...
Check video drivers are up to date.
Check how much free RAM yo have.
Check how much free space you have on your local hard drive.
And make sure Archicad is up to date.
Thanks Barry, now that you say this I have a feeling you're probably right. Will let you know how I go!
Minh Nguyen
Thank you very much for the question! It's an interesting one!
Am I correct to assume that the shadow was broken in OpenGL 3D view and not in PhotoRendering mode with Cinerender? I haven't seen it before, so it would be great if we can have the file for further investigation!
Best regards,
Minh
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
