3D view does not work properly
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2006-11-21 02:58 PM
2006-11-21
02:58 PM
Labels:
- Labels:
Performance
8 REPLIES 8
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-21 07:00 PM
2006-11-21
07:00 PM
Sounds like you have something floating in space VERY far away.
Did you try the PLA on another machine? Might be your video card acting up. Reduce the size of the 3D window if in OpenGL mode.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-21 10:44 PM
2006-11-21
10:44 PM
Djordje, i see only a small portion of the model, i am very CLOSE to it, as if standing within a few feet of the front wall, rather than it being a tiny speck. and, it is rotated perfectly 90 degrees counter-clockwise as the top is to the left. a friend suggested placing a heavy marquee around the plan a viewing 3D as he has had same problem and shook it loose that way > tried that and didn't work.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-21 11:15 PM
2006-11-21
11:15 PM
Djordje, also >> viewing the axonmetric (cmnd-F3) works fine; the perspective view (option-F3) is the problem.
i do have hotfix 1010 loaded and still have problem.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-22 01:33 AM
2006-11-22
01:33 AM
Sounds like a video card problem, but are you sure your roll angle is set to 0 degrees? Check it in your 3D Projection Settings.
Link.
Link.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-22 05:27 AM
2006-11-22
05:27 AM
OK ...
Your viewpoint is screwed up. Nothing wrong with the model, it is the place that you are viewing it from. Practically, you are lying on your side too close to the building.
Open the 3D window settings (CTRL F3), go to Perspective, look at your camera settings. You will see quite crazy values there.
Alternative: place a camera on the plan. Right click on it, choose View all in 3D.
Djordje
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-22 02:43 PM
2006-11-22
02:43 PM
See also:
Perspective View Bug
HTH
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2006-11-22 04:39 PM
2006-11-22
04:39 PM
thank you david and djordje, the view point clue and the perspective view bug explanation made everything happy again.
jeff
jeff
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2007-05-18 01:21 PM
2007-05-18
01:21 PM
46cruisair wrote:
have a model with seven stories. it is somehow corrupted > when i view all in 3D, the 3D view comes in rotated counter-clockwie 90 degrees and see only small part of model; when i click cursor, or type "O" for Orbit and click, or click on "View All" > the 3D image disappears completely. have checked model throughout for duplicates, and for in-line overlapping walls; restart AC10 and computer a few times, saved file as archive. still the same, 3D viewing is impossible. ?? vendor support has not been able to give me fix.
