‎2020-10-25 07:12 AM
‎2020-11-06 11:06 AM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
‎2020-11-13 02:31 PM
‎2020-11-16 02:59 PM
‎2021-09-19 09:45 PM
I have the same problem on mac with Archicad 24 and 25.
‎2022-02-02 07:33 AM
The problem continue to be there.
I have an M1 power book 16 64GB with Monterey AC 25 last update.
I have the same problem I had with the old computer in the first post.
I have a 3dconnexion mouse that I can't use.
This situation is not acceptable.
The 3dconnexion mouse work perfectly with other applications.
Please solve the problem.
‎2022-02-03 01:15 PM
I have a similar problem now as well. Navigation used to be butter smooth now it jumps around and I also have a top-of-the-line mac pro.
Like I said before, there is only a handful of power users who 3D Connexion, and the guy at Graphisoft who use to support this is probably making cabinet objects right now. It's so sad, I brought up these issues to Graphisoft as far as I could and the last thing they told me was that 'we will address it in the next update'. It never happens.
We need to organize a group of people to all at the same time contact them. Otherwise, issues with this will never be resolved, and we have no other realistic hardware or software options.
‎2022-02-18 04:57 AM
Hi Minh,
Are there any updates on Graphisoft's bug fix for the 3D connexion space mouse? Thanks in advance for your reply.
‎2022-02-18 12:55 PM
Hi Tomasz,
Thank you for sharing the issue and I am so sorry for the trouble that it is causing!
We tried to reproduce the navigation issue with the mouse here, but it worked well in 3D navigation on macOS.
For further investigation, may I ask for some details about the working environment you're having?
- The model of the mouse
- The firmware version
- Operating System version
- Archicad version and build number
Best regards,
Minh
Minh Nguyen
GRAPHISOFT
‎2022-02-18 01:21 PM - edited ‎2022-02-18 01:24 PM
Hi Minh
Thank you for your attention.
As I said many times the problems is only with Archicad.
The 3d Mouse work fine with other software.
Can I ask if you can test the button on the 3d mouse; it should open the radial menu (attached). On my computer, in Archicad, I can't see the radial menu ;
Regards
Mario
