Installation & update
3d window object selection issue AC19
Hello, the problem should be clear from the picture (incorrect position of selection nodes and edges, and distorted and like floating textures while rotating model). The last time i've encountered this i have just copied the project to a new file and problem was gone, bus this time is simply too late to do that. Any ideas how to fix this? Archicad 19 for windows
5 REPLIES 5
I think there are already some similar issues reported in this other thread:
http://archicad-talk.graphisoft.com/viewtopic.php?t=50731&postdays=0&postorder=asc&&start=25
Hi Laszlo,
I also get the exact same issue with some models as "majonezas" is describing. Unfortunately the link you posted does not touch upon this same issue or bug.
Has anyone come up with a solution yet?
Which ARCHICAD version are you using?
If you install the latest update and also update you graphics card driver to the latest version, does it still occur?
I am using the latest update on both ArchiCAD (19 SWE 5005 Win64) and graphics card driver.
Then I don't have any good ideas. Please report it to your local reseller.
