A10 Installation Not Working...
First the buttons on the install wizard are not showing up correctly which is a sign to me that it has something to do with the problem, since everyother computer I put the CD in shows up and will do a complete install.
Once it gets to the part right before the files get copied over I hit next and the wizard goes away and never returns.
I have attached a picture so you can see what I mean when I say the buttons are not showing up correctly. (Next, Back, Finished, etc.).
Thanks
3 Replies 3
__archiben
the installer is a java application, so maybe that's the issue? is your version of the java runtime up-to-date? just a wild stab in the dark . . .
~/archiben
b e n _ f r o s t
That was the first thing I checked.
I Uninstalled the version I had and installed the one that was on the CD just to make sure I had the right version.
I think I'm going to format the hard drive today and reload everything.
I have same problem. Think is the java machine... i tried to reinstall but nothing seems to work.
P4 3.6, 1Gb ati x800 , winXP.
