AC-11 is showing two projects at once....
I've just had a weird experience. After looking at a layout, I used F2 to switch back to Model view. I was brought back to the model view of the project I had been working on before this one.
I had been working on project X, finished, saved, and opened project Y.
I worked on project Y for about half an hour, then switched to layout view to check the floor plan output. When I used F2 to revert to model view, the project X model view showed up. Using either CMD-` or the navigator to switch between windows had the same results. Closing and reopening has (knock wood) cured the problem so far.
Whiskey Tango Foxtrot?
I have had many of the problems others have reported in installing Hotfix 1200, and finally succeeded with a reinstall from scratch. So far AC-11 is resistant to Hotfix 1210, and I don't want to go all the way through from scratch again.
Any ideas?
5 REPLIES 5
Dwight
Before you call a priest, just be sure you don't two Archicads open at once.
Dwight Atkinson
Dwight:
That was the first thing I checked...
Stress Co_
I've had something similar happen in the Navigator Preview window. "Redraw Preview" and it was gone.
Marc Corney, Architect
Red Canoe Architecture, P. A.
I've also experienced this, although only 3 times in the last 4-5 months. Unfortunately, in 2 cases it happened sitting in front of a client - very embarrassing. The only possible trend is that it seems to happen if I go straight to the 3D window after opening a project and do a few operations there. When I go back to the 2D plan, I'm looking at the previous project. Eventually all views display the previous project and all changes I've made are lost. Weird in the extreme!
Ralph Wessel BArch
Central Innovation
Djordje
I had it in Organizer ... also Navigator Preview.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
