2021-07-16 06:14 AM - last edited on 2024-01-29 10:52 AM by Aruzhan Ilaikova
2021-07-16 02:23 PM
Ignacio wrote:I've occasionally had this problem with AC24 and Mac OS10.14 Mojave when moving the dongle between computers. Removing the dongle, then reinserting, so the light only blinks once, solves it. I think I saw the dongle show up on the desktop as a drive with the multiple light blinking, so I guessed it was being seen as a storage device.
When I insert the Codemeter key, the light blinks intermittently green-orange for a few seconds and then goes off.
2021-07-16 02:33 PM
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-07-16 02:40 PM
mnguyen wrote:In my case, the dongle had been converted to HID.
The keys need to be converted into HID.
2021-07-16 02:45 PM
Minh Nguyen
GRAPHISOFT
2021-07-16 03:42 PM
Minh Nguyen
GRAPHISOFT
2021-07-16 03:55 PM
2021-07-16 09:50:46: proxy: system proxy - host: '', user: '' 2021-07-16 09:50:46: No Kext installed. Using FileIO. 2021-07-16 09:50:46: CodeMeter for macOS/x86_64 (B7.20.4402.501.64.1200) 2021-07-16 09:50:46: Running on Mac OS X 10.15.7 2021-07-16 09:50:46: Execution path: /Applications 2021-07-16 09:50:46: Found IPv4 address: 127.0.0.1 2021-07-16 09:50:46: Found IPv6 address: ::1 | fe80::1%lo0 | fe80::aede:48ff:fe00:1122%en5 2021-07-16 09:50:46: Used Communication Mode (Client): IPv6 IPv4 2021-07-16 09:50:46: Used Communication Mode (Server): IPv6 IPv4 2021-07-16 09:50:46: Used IP address: 127.0.0.1 2021-07-16 09:50:46: Used IP port: 22350 2021-07-16 09:50:46: Used CmWAN port: 22351 2021-07-16 09:50:46: Run as network server: no 2021-07-16 09:50:46: Run as CmWAN server: no 2021-07-16 09:50:46: Run as system service: yes 2021-07-16 09:50:46: TMR-Mode: disabled 2021-07-16 09:50:46: Box Access: use FileIO 2021-07-16 09:51:54: Removable Device has been plugged IN! 2021-07-16 09:51:55: EBL-Trace: 2021-07-16 09:51:55: EBL-Trace: 2021-07-16 09:51:55: EBL-Trace: 2021-07-16 09:51:56: EBL-Trace: 2021-07-16 09:51:56: EBL-Trace: 2021-07-16 09:55:10: Removable Device has been plugged IN! 2021-07-16 09:55:14: Removable Device has been plugged IN! 2021-07-16 09:55:14: EBL-Trace: 2021-07-16 09:55:14: EBL-Trace: 2021-07-16 09:55:14: EBL-Trace: 2021-07-16 09:55:14: EBL-Trace: 2021-07-16 09:55:14: EBL-Trace: 2021-07-16 10:03:37: Removable Device has been plugged IN! 2021-07-16 10:03:37: EBL-Trace: 2021-07-16 10:03:37: EBL-Trace: 2021-07-16 10:03:38: EBL-Trace: 2021-07-16 10:03:38: EBL-Trace: 2021-07-16 10:03:38: EBL-Trace: 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to SubSystem (Handle 16) 2021-07-16 10:28:33: API Event WB201 (BOX NOT FOUND) occurred (returned to caller) 2021-07-16 10:28:33: Handle 16 released 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to SubSystem (Handle 17) 2021-07-16 10:28:33: API Event WB201 (BOX NOT FOUND) occurred (returned to caller) 2021-07-16 10:28:33: Handle 17 released 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to SubSystem (Handle 18) 2021-07-16 10:28:33: License information imported successfully 2021-07-16 10:28:33: Detecting CmContainer with Serial Number 32767-34945 2021-07-16 10:28:33: Found new entries: 1 2021-07-16 10:28:33: Handle 18 released 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to SubSystem (Handle 19) 2021-07-16 10:28:33: Handle 19 released 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to IFI (Handle 20) 2021-07-16 10:28:33: Handle 20 automatically released (rescan) 2021-07-16 10:28:33: API request failed, Handle 20 is invalid. 2021-07-16 10:28:33: API Event WB106 (INVALID HANDLE) occurred (returned to caller) 2021-07-16 10:28:33: Access from local(IPV4)(Ignacio) to SubSystem (Handle 21) 2021-07-16 10:28:33: Handle 21 released 2021-07-16 10:28:33: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:33: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:33: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:33: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:33: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:33: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:33: Executing Broadcast for CodeMeter License Servers 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:34: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:34: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (101074:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (5000003:61:137887743) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Entry (6000170:61:4168089601) not found - Event WB0200 (ENTRY NOT FOUND), Request IP-Address local(IPV4)(Ignacio) (SID 0xce) with StationShare Mode 2021-07-16 10:28:35: API Error 200 (ENTRY NOT FOUND) occurred! 2021-07-16 10:28:35: Access from local(IPV4)(Ignacio) to SubSystem (Handle 88) 2021-07-16 10:28:35: API Event WB201 (BOX NOT FOUND) occurred (returned to caller) 2021-07-16 10:28:35: Handle 88 released 2021-07-16 10:28:35: Access from local(IPV4)(Ignacio) to SubSystem (Handle 89) 2021-07-16 10:28:35: API Event WB201 (BOX NOT FOUND) occurred (returned to caller) 2021-07-16 10:28:35: Handle 89 released 2021-07-16 10:28:35: Access from local(IPV4)(Ignacio) to SubSystem (Handle 90) 2021-07-16 10:28:35: License information imported successfully 2021-07-16 10:28:35: Detecting CmContainer with Serial Number 32767-34945 2021-07-16 10:28:35: Found new entries: 1 2021-07-16 10:28:35: Handle 90 released 2021-07-16 10:28:35: Access from local(IPV4)(Ignacio) to SubSystem (Handle 91) 2021-07-16 10:28:35: Handle 91 released 2021-07-16 10:28:35: Access from local(IPV4)(Ignacio) to IFI (Handle 92) 2021-07-16 10:28:35: Handle 92 automatically released (rescan) 2021-07-16 10:28:35: API request failed, Handle 92 is invalid. 2021-07-16 10:28:35: API Event WB106 (INVALID HANDLE) occurred (returned to caller) 2021-07-16 10:34:35: API Error 221 (NETINFO FAILED) occurred! 2021-07-16 10:34:35: API Error 221 (NETINFO FAILED) occurred! 2021-07-16 10:35:12: Error: No data received in new connection (timeout). 2021-07-16 10:35:40: API Error 221 (NETINFO FAILED) occurred! 2021-07-16 10:35:40: API Error 221 (NETINFO FAILED) occurred!
2021-07-16 04:07 PM
Minh Nguyen
GRAPHISOFT
2021-07-16 10:30 PM
