2024-02-15 07:48 PM - edited 2024-02-16 01:53 AM
New Text bug in the preview release.
For text units set to points, you CANNOT TYPE two digits in the input field,
If you want to change your text to "12" points it will only let you type the first digit.
Workaround is to move the cursor back next to the first digit and type the next number.
This only happens on a new file started in 27.2.0 and on every text input field
Operating system used: Mac Apple Silicon Preview
another Moderator
Solved! Go to Solution.
2024-02-16 09:31 PM
Creating a new file and using default W/E cleared the issue.
Looks like a preference got stuck upgrading.
another Moderator
2024-02-16 09:31 PM
another Moderator
