Installation & update
AC Build 4008
I got a message that my AC17 was out of date and downloaded the Hotfix3 build 4008, but when I go to install it on the BIM server it doesn't update. When I check for updates on the BIM Server, it says it's up to date. I won't install this on the local Archicad program, as they always warn you that the BIM Server and the archicad program have to have the same build number... What's up?
5 REPLIES 5
Eduardo Rolon
Read the notes
http://www.graphisoft.com/support/archicad/downloads/update.html?_submitted=1&version=17&lang=USA&bu...
Eduardo Rolón AIA NCARB
AC28 US/INT -> AC08
another Moderator
aaahhh... Sorry, skipped right over that!
Also to install hotfix 3 (build 4008) which is only an update for BIMx Hyper-model, you must first install hotfix 2 (build 4005).
If Archicad is telling you it is out of date it should point you to the correct hotfix.
But just make sure you do not try to install 4008 before you have installed 4005.
Eduardo Rolon
Barry wrote:
But just make sure you do not try to install 4005 before you have installed 4008.
4008 before 4005?
AC28 US/INT -> AC08
another Moderator
ejrolon wrote:
4008 before 4005?
Woops.
Fixed.
