AC11 trial
Every time I try to install the trial vesion I get an error message saying that it can't continue because of limited hard disk space in the ArchiCAD temp folder. The temp folder is empty. I'd really like to try it out because we are thinking of upgrading......Any thoughts? Thanks Doug
15 Replies 15
Did anyone sort this problem out? I am getting the same error and do not know what to do next. Please can anyone help move this forward.
XP Pro, 4GB Ram, Intel Dual Core
Is there any fix to this? I have 38gigs free on my hard drive and 2gigs of RAM so my computer should be able to handle this.
Has anyone figured out a fix for this problem?
Thomas Holm
http://archicad-talk.graphisoft.com/viewtopic.php?p=107280#107280
hallo,
i registered and downloaded the student version of archiCAD 11.
i also got the e-mail with my temporary serial number.
i ran setup - had to choose between commercial, educational and trial version - i choose trial v., wrote my serial number , but couldn't get to the next step
- i choose edu v., wrote my serial number , but couldn't get to the next step
- i choose commercial v., i didn't have to write the serial number and it got installed
now my problem - i want to ran the program and it opens a window: "Protection key not found or not valid. (1050017)".
i get the option to run the demo version but there i can't save, copy and teamwork functions are disabled.
thank you ,
ioana
You need to select the EDU version for this to work, I think.
If you select the commercial version, then you will need a hardware key (a device that is about the size of a flash drive and fits into your USB port) to ba able to use AC in non-demo mode.
Make sure you are logged in as an Administrator when trying to install.
I wound up calling Graphisoft for a copy of it on cd.
