Jeff Kogut
AC19 3D Explore window 'drifts' when stopped
Built a new PC this week with Windows 10, Quadro P600, and have AC19 and AC21 installed. AC21 has no issues.
I have several projects to continue work on in AC19 and now when I move around in the 3d Explore window and then stop moving the view slowly 'drifts' in the direction I last moved. This applies to side input from the mouse and panning/up/down movement from the keyboard. I need to put in some counter input with the mouse to stop the drift. Not a show stopper, but annoying.
The only time this doesn't immediately happen is if I'm moving directly forward and then stop.
I had previously started this file on an iMac.
I checked the work environment. Latest Quadro drivers. All Windows updates. Any ideas?
AC19-23 | Win10 Pro | i7-8700K | Quadro P600 | 500gb 960 EVO M2 | Dual 28" 4k Samsung U28E590
7 Replies 7
Erwin Edel
Maybe a mouse driver issue?
I haven't used ArchiCAD19 for over a year, since we run everything on ArchiCAD20 now, even the projects started in 19, but I do not recall having this issue on Win10 at the time.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Jeff Kogut
The one thing I didn't even consider Erwin! Alas, it's just a MS Wheel Mouse with vanilla driver and I can't seem to turn anything off to change this.
Erwin Edel
I don't suppose you have ArchiCAD20 as well? I have no issues with any projects from 18/19 in ArchiCAD20.
I notice you are running two 4k screens, maybe ArchiCAD19 doesn't like the high res as much as 20/21.
www.leloup.nl
Jeff Kogut
We're transitioning to 21, but I have some projects I'd like to keep 19.
Erwin Edel
With the stair tool (and teething problems of 21) I can understand that. 20 is working fine, also for 19 projects, you just get the UI update (and properties and some other updates), but I suppose it is 19 or 21
Maybe try running the screen at half resolution to see if that is causing it.
www.leloup.nl
Erwin Edel
Should also say I am running two HD screens, not 4k here.
www.leloup.nl
Jeff Kogut
$310 each.
https://www.amazon.com/Samsung-U28E590D-28-Inch-LED-Lit-Monitor/dp/B00YD3DBOC
I like them, though the color is not quite up to the Apple 5k i5 system I was using but those LG monitors Apple uses are $1300 each.
