AC19 Slow Paste
Has anyone else noticed incredibly slow paste function?
I mean 49 seconds for a bit of text.
Only seems to be a problem in large files
4 Replies 4
If only occurs in large files check your ram usage, you may be swapping to disc which is several thousands of times slower than operations in ram
Scott
Thanks Scott,
RAM is good, but CPU seems to be on limit on one or two of my cores
Try to update to the latest build of AC18.
There were several pasting-related issues were fixed in the hotfixes, maybe it will help your situation as well:
http://www.graphisoft.com/downloads/archicad/updates/AC18/ImprovementsList.html#8004
Katalin Borszeki
Hi All,
We got news from the user that his problem was fixed by our Techical Support Staff, and did not recur since the last update.
best,
Katalin Borszeki
Implementation Specialist
GRAPHISOFT
