AC20 on Windows 7
Hi All,
Can AC20 run on Windows 7?
I got an error message: "error missing QTCF.dll"
It is said, it come from the latest Quicktime, but that one cannot be installed on windows 7.
Any sugesstion please?
Thank you.
Yes, I am running ARCHICAD 20 on Windows. GRAPHISOFT states Windows 7 is compatible with it (but not tested on it):
http://www.graphisoft.com/support/system_requirements/AC20/
As far as I know AC18 an newer version do not use QuickTime at all, so it is strange error message:
http://helpcenter.graphisoft.com/technotes/setup/quick-time/
You can try installing QuickTime and see if that makes any difference.
(I have QuickTime installed in my Windows 7 system so I can run AC17 or older in case I need to.)
Thank you Lazlo,
Installing the latest QuickTime didn't help.
Finally, I seek for the specific .dll on the web:
https://www.dll-files.com/qtcf.dll.html
and then I just put it on the C:\Windows\System32\
The installation went well to the end.
Glad you got it working.
