ā2018-06-28
09:54 AM
ā2024-02-27
05:18 PM
Aruzhan Ilaikova
ā2018-06-28 10:11 AM
lagodue wrote:If you mean that you have moved elements to the Archicad layer then it can't be a layer issue.
I have even put the problem layers on the Archicad Layer as a test, and they still do not appear.
ā2018-06-28 06:46 PM
ā2018-06-28 07:15 PM
ā2018-06-29 02:35 AM
ā2018-06-29 02:38 AM
lagodue wrote:If you are placing 'New' elements then so long as the active renovation filter is set to either show or override new elements, then you should be able to see them.
OK let me try another question: when I start a new project with all work NEW, do I have to set the renovation filter in any particular way? Seems to me the default should be ALL NEW WORK.
Thx
