AC22 screen setup
cpeeps
I have upgraded from AC17 to AC22. I would like to import all my default screen setups (menus, tools, etc.) from 17 to 22 so that it looks just the same. Is there a way to do that?
Lee Hankins
You can export your work environment if you have saved it from AC17 and import it to AC22. However, there are limitations to this. Any new menu commands would be automatically turned off and disabled in AC22 so it is not recommended. You can import the separate elements of the Work Environment and avoid the part which affects menu layouts.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
You can also export-import your Work Environment Menu and Toolbar settings separately with a little tweaking:
https://community.graphisoft.com/t5/Wishes-forum/Create-a-seperated-profile-for-Menus-and-toolbars/t...
