2020-01-23 05:47 PM
2020-01-28 03:17 PM
2020-02-05 08:56 AM
peon2t wrote:Hi peon2t,
Hi
One of our CAD ladies sometimes works from home. This means she does a RDP-connection from her home to her workstation in our office and then uses the workstation more or less as if she were in the office.
Now since we installed AC23 this setting gives us a strange problem: When she's connected via RDP and hits the "Open Project" button, it takes ages (she said: up to an hour) before the "Open project dialogue" shows and she can start working.
However when she's working locally at the office, there is no such issue.
It's to be mentioned that:
a) there was (and is) no such problem with AC22 or previous versions. It's only AC23.
b) all other software behaves 100% normal when used via RDP
So we figure that AC23 must have introduced some kind of strange bug that causes this...
What's also strange is that she can't open an project in AC23 by clicking the file in the folder where it's stored.
Shecanchose "Open with..." -> and then AC23... but it always opens with AC19... the projects are opened with AC19 even if you throw them directly at the AC23 exe... because of this we can't easily "work around" the bugged opening dialogue.
Thanks for any ideas.
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-02-10 12:49 PM
Minh Nguyen
GRAPHISOFT
2020-02-12 04:47 PM
2020-02-15 11:54 AM
2020-02-17 01:55 PM
Minh Nguyen
GRAPHISOFT
