Duane Meyers
AC26 6002 Upgrade/AC26 will not even open
I have been having issues with AC27/Sonoma. So today I backed down to AC26 and noticed there was an AC26 6002 Upgrade so I downloaded it, installed it and now I can't even get AC26 to open. In trying I get the following prompts...
1. That I am not signed in and I have 23 days to use ArchiCAD
2. Internal error found, ArchiCAD will be closed.
I cannot express how frustrating this is when I have work to get out!
Screenshot 2023-11-15 at 6.23.58 PM.jpgScreenshot 2023-11-15 at 6.26.00 PM.jpg
17 Replies 17
Gene Kniaz
Not early days . . . It was immediately evident when you did the install update.
Gene Kniaz, Architect
Principal | SPIRAL ARCHITECTS
Tucson, AZ, USA
AC6.5-AC28 Intel i9 10c iMac AMD RP 5700 XT 16 GB 128MB
Gene Kniaz
Also, "local support=useless".
Tucson, AZ, USA
DGSketcher
Legend
I see AC26 UKI 6002 (update 4) INTEL has been pulled from download (as at 17/11/2023)
Eduardo Rolon
See here:
https://community.graphisoft.com/t5/Graphisoft-Insights/Slow-Archicad-26-startup-after-installing-Up...
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
SeaGeoff
Ace
It appears all the 600x updates have been pulled. Not before I ran it on 26 INT which now won't open. (It's not the open delay, that is another bug), I get the following error. I can assure you the listed add-on are indeed located in the proper folder. Sorry but this is an embarrassing sh*t show. Between the Sonoma crashes and this debacle Graphisoft quality control appears nonexistent.
Regards, Geoff Briggs
I & I Design, Seattle, USA
AC7-29, M1 Mac, OS Tahoe
Graphisoft Insider's Panel, Beta Tester
Gene Kniaz
Hi Eduardo:
Thanks for posting, but for the life of me, I cannot find that subdirectory, unfortunately.
If anyone has used this workaround successfully, please post about it! I set a timer on my watch for 15 minutes to see if it does in fact open after "10-15 minutes"; wish me luck!
Tucson, AZ, USA
Gene Kniaz
Hi all:
I wasn't able to find the "IPC Data" sub-directory noted in this workaround post, but I did fire up AC 26 6002, and it did finally start up - after about 25 minutes. There was no sign of any activity at all, but I just did other stuff, and eventually it popped back up. Just FYI.
Tucson, AZ, USA
SeaGeoff
Ace
For future reference, the last few versions of macOS have hidden the user library. To find it make Finder active and open the Go menu. Now press the option key and you will see Library magically appear. Open the Library and navigate its contents in the normal fashion.
