AC9 and WiBu-key
Hi
I installed the Wibu-key on our server (XP with sp2). I installed AC9 on a client (XP with sp2) and I can use AC9 in other words there is communication with the WiBu key on the server.
For some reasons I had to change the subnet on our network. From that moment I can NOT use AC9 on this client. A re-install (recommended by our supllier) of AC9 is no solution.
On other clients, on which AC9 is installed after the change in subnetting was made, AC9 works just fine.
any idea?
10 Replies 10
scottobrien wrote:
Check your wibu key settings on the server and the wibukey.ini on the client and confirm the settings match. Ip Address and port # etc. Be sure to un-comment the "Server="Your server ip address"" under the [WkLAN Client] heading.
Open your web browser and insert the following : "YourServerIPAddress:Port#ofWibuKeyServer" ex. "10.0.201:22347" or "192.168.1.1:22347" This should call up the WIBU-KEY Server Web Monitor page. If not I would guess you have a network issue.
On the client does AC start when you plug the key directly into one of the ports?
-Scott
from the browser I can not call up the WiBu-key Server Web Monitor, nor from a workstation nor from the server.
When this workstation is also WiBu-key server AC will not launch
