Installation & update
AC9 sudden shut down
I'm guessing this has been talked about before, but I couldn't find it. My AC9 is shutting down very, very suddenly. I'm finding it happens mostly when I go to my Axonometry view or my perspective view. However, I have seen it happen a couple of times going to elevations.
We are talking about very, very sudden shut downs. No pausing, no stalling, no bug reports, no nothing. Just one second it is there and the next second it is totally gone and my computer is running as if nothing had happened.
I'm running a Dell Dimension 9100 with a 2.8G Dual Core Technology Processor with 1.5G of RAM. Windows XP, serice pack 2.
This has just started happening maybe within the last week. Any guesses? Any ideas would be helpful. Thanks.
Erika Epstein
It sounds like there might be a problem with a bad library part or inverted slab or something of that nature. Have you received any error messages prior to this?
Try marqueeing smaller areas of your model and generating 3D from it to find the part(s) of your model that are causing this behavior. If only some of your elevations are causing this then that is a good clue as to which part of the model may be problematic.
Which libraries and add-ons are you using?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Rob
mate,
it sounds to me like you need to get your graphic card drivers updated...
check this out: http://archicad-talk.graphisoft.com/viewtopic.php?t=8077
::rk
