2019-10-09
02:22 AM
2024-01-31
01:32 PM
Aruzhan Ilaikova
2020-01-16 11:29 AM
TRhodes wrote:Unfortunately, for us, it seems this was a false dawn - the problem persists...
And we have a solution! from the Graphisoft development team;
Thank you for the screenshots, that was a huge help! As I checked, the driver for Intel graphics card was not updated. The latest version is .7584, that can be found via this link: https://downloadcenter.intel.com/download/29274. It will update the graphics card used in client machine, which is Intel UHD Graphics 630.
In Intel's release notes, it is mentioned that: "Intermittent crash or hang may be observed when launching or closing ARCHICAD* application" has been fixed. Could you ask the client to update the graphics card driver to see if this can help with the issue? It does not sound like this has something to do with Sophos, but we suspect that maybe the process mentioned yesterday is blocking ARCHICAD at kernel level.
2020-01-23 01:08 PM
2020-05-15 04:39 PM
2020-05-19 08:58 PM
thom_93 wrote:Hi,
I have it running on Mac OS Catalina 10.15.4 and I've been facing the same issue. I can't get past the browse, new, open part without it freezing completely. Even the bug reporter freezes!
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2020-06-09 11:04 PM
2020-06-10 01:35 PM
Minh Nguyen
GRAPHISOFT
2020-06-15 05:09 PM
2020-06-16 03:16 AM
toofuerte wrote:
I have an issue when I have opened 5 instances of Archicad
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 7800X3D | 32GB | RTX5070TI |
2020-06-16 01:34 PM
toofuerte wrote:Hi Gary,
I have an issue when I have opened 5 instances of Archicad. If i start a new instance and select browse or teamwork button it hangs i have to end task on the task manager to get out.
Also my start screen doesn't update the projects showing are the same ones from a few weeks ago, I have opened up new projects but they are not showing on the recent projects. I have windows 10 so that is not an issue and it is up to date.
Minh Nguyen
GRAPHISOFT
2020-06-20 03:17 AM
