Steve Jepson
Accessories and add-on file size
From Windows Control Panel select Add or Remove programs and sort by file size. Does anyone using Windows XP Pro x64 see huge file size for add-ons ? Tech Support confirms that it's only cosmetic. Files are not that large. They show up here because an installer was used to load them.
1 Reply 1
I am only using XP 32 bit but see the same thing.
In my case all 900MB.
Seems they all match the same size for the Archicad 14 install.
