Installation & update
Accessories and add-on file size
Steve Jepson
From Windows Control Panel select Add or Remove programs and sort by file size. Does anyone using Windows XP Pro x64 see huge file size for add-ons ? Tech Support confirms that it's only cosmetic. Files are not that large. They show up here because an installer was used to load them.
1 REPLY 1
I am only using XP 32 bit but see the same thing.
In my case all 900MB.
Seems they all match the same size for the Archicad 14 install.
