‎2009-01-06 02:59 PM
‎2009-01-07 10:44 PM
‎2009-01-07 11:13 PM
Laura wrote:This is similar to what Karl reported here.
When Complex Profiles was a new feature, I remember having problems with profiles containing numerous nodes -- when editing the profile, nodes were often "left over" from where fills once met, creating a number of extra nodes on what would be a planer surface -- I assumed that "extra nodes" meant "extra polygons", which is why it was causing problems (model slow-down, walls not joining correctly) -- I eliminated any extra nodes, and eliminated the problems.
Have you had any problems modeling brick walls in this manner?
‎2009-01-08 06:44 PM
Link wrote:Ah -- interesting -- thanks, Link. I remember the extra nodes causing problems, but this was when AC10 was new and I was working on a building with complex geometries (all sorts of abstract angles joining in different ways), I haven't had problems with Complex Profiles since.
‎2009-01-26 03:11 AM
If we're straying into wish lists for walls then one we have is that you can create a wall based upon brick/block dims. AND have it visible and accurate when you drop a section through the wall.if i'm understanding this comment correctly, this is possible by creating a new fill with the appropriate course dimension and assigning it to the composite wall leaf or cut section fill
