2020-07-30 01:23 PM
2020-07-31 03:44 AM
benanna88 wrote:I doubt you can import an entire work environment from a newer version to an older version.
I am working on a project at the moment for someone who is using ArchiCAD 16, and so I am working in that version as well, but have found a couple of issues with it. Hope it's OK to put both issues in the same thread, given it's an older version.
The first is that I am trying to import my work environment settings from a newer version, but whenever I click on import, the window opens and freezes ArchiCAD straight away, and then after a few minutes it crashes. Does this sound familiar to anyone, or any suggestions to get around it? In particular I don't want to have to set up all of my keyboard shortcuts or any other more fiddly work environment settings.
benanna88 wrote:
And the second issue is that default grid is rotated relative to actual '0°' in the project, if that makes sense. The simplest way to show it is in a section, where I don't believe you can have a rotated grid, but as you can see in the attached screenshot, ArchiCAD thinks 0° is at an angle to true horizontal or vertical. Any idea what would cause this, or how to fix it?
2020-08-02 06:23 AM
2020-08-02 08:29 PM
2020-08-02 11:12 PM
2020-08-03 03:44 AM
2020-08-03 03:50 AM
2020-08-03 03:50 AM
2020-08-04 12:47 AM
