ArchiCAD & PDF problems
I have a bit of a problem that came at the wrong time. All of a sudden I can't print to the PDF writer. I have the driver that came with AC, and I installed Adobe Accrobat on top of that. I uninstalled and reinstalled Accrobat, but whenever I try to print, one of these two drivers/software just hangs.
Question: is there a way to uninstall AC's pdf creation utility or to disable it? Or has anybody else had to deal with this and resolved it effectively? Or is there something else I should be looking into?
Thanks for all y'all's help.
Link
Have you tried simply reinstalling the Amyuni PDF Converter again from Start>All Programs>ArchiCAD 8.1? Not sure if it'll work, but it may be a quick fix!
Link.
Yes, I've tried that also and that didn't help either. I'll need to uninstall all adobe reader type products and then reinstall them one at a time and see what happens. If there's any other ideas in the meantime.... I'll be listening.
