[ArchiCAD26 EDU] - Error at startup, libmmd.dll missing
DawsonL
Hello Everyone, I'm currently struggling with the "libmmd.dll" error at startup on ArchiCAD26 EDU. I have contacted my local support regarding Archicad but they didn't know how to resolve the problem either so that's the reason for the post.
I have uninstalled and reinstalled Archicad from scratch multiple times. This did not resolve the issue.
After that, I proceeded to uninstall and reinstall Cinema 4D.  This ended up not working either.
Link: "https://Graphisoft.com/downloads/addons/cinema_4d/cinema4d_download"
After further research, I stumbled across a post about this issue with a previous version of Archicad.
Link: "https://community.Graphisoft.com/t5/Setup-License-forum/ArchiCAD25-Error-at-startup-libmmd-dll-missi...
Unfortunately, I did not see which visual C++ version had to be used for Archicad 26 EDU.
Many thanks in advance and kind regards,
Dawson
They are links to the old forum.
Here is a link to an article in this forum (a simple search found it).
https://community.graphisoft.com/t5/Let-s-get-started/Archicad-26-Install-and-Start-up-Troubleshooti...
It will link you to another article that has the 3rd party installers you need, but only goes up to version 25.
I would give that a go (I think the C++ installer might be the same one you want.
I have asked in the comment section if there is an update for 26, so keep an eye on that.
I wanted to comment on this. I used the post "3rd party installers for Graphisoft products" which lists the additional software for the usage of Archicad 21-25.
https://community.Graphisoft.com/t5/Setup-License-articles/3rd-party-installers-for-Graphisoft-produ...
I installed all the Archicad 25 additional software, and didn't reinstall it but used the "repair" function which checked the software and repaired it. I proceeded to launch Archicad 26 and it worked fine after. The issue of the libmmd.ddl missing was resolved. I assume it was an issue with one of the software that was installed prior.
Regards,
Dawson
