2007-12-10 11:37 PM - last edited on 2024-07-03 02:29 PM by Aruzhan Ilaikova
2007-12-13 02:37 PM
peach49 wrote:You may have 40GB HDDs on both machines but, for sure, the free space available on your C: drive will not be identical on both PCs. Since your RAM is so low, ArchiCAD will try to push things into a page file on your hard disk and, if the available space is insufficient, will be unable to load completely.
Ok my computer has 40gb of memory..and 256MB of RAM...yet i have another computer with the same spec that runs the program perfectly well...and im using a student licence
peach49 wrote:Actually, I'm really surprised that AC-10 works at all on your other machine. With 256MB, XP alone just crawls! Here are the system requirements according to Graphisoft:
My machine more than matches up to the requirements of archicad...
2007-12-13 09:56 PM
laszlonagy wrote:Yep the bug report comes up but the result of it is fruitless...iv tried installing archicad again and even installed archicad 11 with the same problem...and i have the same program on exactly the same spec pc but with no problems whatsoever.
Some questions:
Does any ArchiCAD bug report come up? If yes, you can send that to GS.
Have you tried reinstalling ArchiCAD to see if that helps. Maybe there was something wrong with the installation?
Can you try if this happens on another computer as well or only this one?
2007-12-14 10:53 AM
peach49 wrote:If you have two pcs with same specs and AC runs on one but not on the other, then I would some something may be wrong with that pc, maybe one of its hardware components or possibly a system driver problem like graphics card driver?laszlonagy wrote:Yep the bug report comes up but the result of it is fruitless...iv tried installing archicad again and even installed archicad 11 with the same problem...and i have the same program on exactly the same spec pc but with no problems whatsoever.
Some questions:
2007-12-14 12:00 PM
2008-03-04 01:46 PM
2008-03-04 06:25 PM
Cristina wrote:The report goes straight to Graphisoft, not your reseller. You should quote the code when talking to him, so that he can follow up.
Hi, I'm having a similar problem with AC11. Two weeks ago it worked perfectly and now, when I try to open the program I receive a bug report. I sent it and received a code. I contacted my provider who told me that I didn't send anything cus he checked it out (I don't know what that means). So... if you could help me I'd be grateful cus I don't have the time to wait for the provider to figure it out.
I'm using Windows XP, Pentium3,2, 1Gb RAM.
2008-03-05 08:32 AM
